Canon EOS Rebel T5 LCD Screen Replacement
crwdns2942287:0crwdne2942287:0If the display on your camera has stopped working or is cracked and otherwise not functional, it will need to be replaced. This guide will show you how.
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
Lift the now free card/battery door to reveal the battery compartment.
Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
Turn the camera so that the back is facing to your right.
Remove the 5mm JIS #000 screw above the rubber USB port cover.
Remove the rubber piece.
Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
Turn your camera so that the bottom is facing you.
Remove the 5mm JIS #000 screws.
Now turn the camera so that the front is facing towards your right.
Remove the two remaining 5mm JIS #000 screws.
Instructions are forgetting the two screws on either side of the viewfinder…. Viewfinder slides up to reveal two screws.
Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
Gently pry the back panel from the main body of the camera.
Do NOT pry until you’ve removed the eye gasket, and the 2 screws behind this! You will break the camera.
Remove the four silver 4mm JIS #000 screws connecting the LCD screen to the back of the camera.
Be sure to lift the ribbon cable to remove the remaining hidden black 4mm JIS #000 screw.
The circled screw on the bottom in the middle isn’t a screw, it’s an alignment nub. The 4th screw is behind the black flex.
The LCD screen can now be lifted from the right side to be replaced.
New LCD pressure fits into metal carrier tray. Assemble back together upside down, or LCD will fall out of tray.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:08crwdne2947412:0
This guide is NOT COMPLETE. THere are several missing screws that need to be removed.
2 from the viewfinder,
and 2 from the IO ports....
Do not follow this and force the back open or you will need more repair!
Hi, I followed every step and replaced the LCD screen but when turned on the camera, I only got a yellow horizontal line. Do you know what could have gone wrong? Thank you.
Hi, excellent guide but I’ve a problem.
I’m need to buy a lcd display. Do you know where can I buy ? Can you recommend me one store to buy it?
@nickmorales I found the lcd display as well as the connected controller card ar eBay.
Tom Kane
I had problems connected the actual LCD component to the controller card, as seen in step 9. We need more illustrations for actually connecting the ribbon cables (plural!) and for actually mounting the LCD and the controller card.
Tom Kane
11romej is correct. There are an additional 4 screws that must be removed not still not shown in the tutorial as of March 29, 2019. Much easier to accomplish this repair with a fine tipped pair of tweezers.
I can’t get the hinged piece to stay closed and keep computer ribbon on back of LCD screen in place. Any suggestions.
Yes, this worked well. You did miss 2 screws under the viewfinder but the rest was spot on. Thank you...you saved me about $200 by repairing the camera myself
