Using these instructions, we'll make it easy and simple for you to replace the LCD screen in your Canon camera.
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Push the grey tab on the right side of the battery.
Remove the battery from the slot.
Remove the six screws on the housing of the LCD.
Four 3.1mm JIS screws on the side with the hinge.
Two 2.7mm JIS screws
Unplug the blue cable attached to the back of the LCD.
where can I buy a replacement LCD screen for my EOS650D camera in Adelaide. Australia
If it helps any, the part number for the LCD screen is CG2-4025. You can also try just searching something like "Canon EOS 650D LCD screen" on eBay to find a replacement screen.
Zephosk -
