This guide details how to replace the flash bulb of this camera.
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Push the grey tab on the right side of the battery.
Remove the battery from the slot.
Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
Use the wire cutters to cut the wiring connected to the flash.
crwdns2935229:010crwdne2935229:0
how do you reverse step 6 - cutting the wires?
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
