This guide will inform the user what to do if the battery needs to be replaced.
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Push the grey tab on the right side of the battery.
Remove the battery from the slot.
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
