Canon EOS Rebel T3i Motherboard Replacement
  1. Canon EOS Rebel T3i Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery compartment on the bottom of the camera.
  2. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hook your finger onto the compartment door latch.
    • Open the battery compartment door.
  3. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the compartment.
  4. Canon EOS Rebel T3i Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel away the rubber grip on the left side of the camera with your fingers.
    • The grip should feel like a thick sticker as it comes off.
  5. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 3 mm JIS #000 screws on the left side of the camera.
  6. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 3 mm JIS #000 screws on the bottom of the camera.
    I’m using the 000 screwdriver but the screws won’t come lose. Does anyone have a solution?
    Joran Peeks - crwdns2934203:0crwdne2934203:0
  7. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3 mm JIS #000 screws on the right side of the camera.
  8. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back of the camera by lifting from both the left and right sides.
    • Be careful not to break the orange and blue cables connecting the back panel of the camera to the motherboard.
  9. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the orange cable at the bottom of the camera by gently pinching with your fingers.
  10. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the blue cable by sliding the pointed end of a spudger between the motherboard and the silver prongs connected to the cable.
    where can I order this blue cable? I broke mine when performing this step:(
    Rob Waterman - crwdns2934203:0crwdne2934203:0
  11. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the cable on the top left corner of the motherboard.
    • Pinch the round, white connector with tweezers and gently remove the cable.
  12. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With tweezers, pinch the ends of the remaining orange ribbon cables, and gently pull these ends off of the motherboard.
    • Leave the other end of all ribbon cables attached to their components.
    • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
    • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
    Sometimes it’s easier to use a spudger to lift the plastic rails holding the cables in place, and using the edges of the cable and the pointed end of the spudger to push them out.
    Máté Homolya - crwdns2934203:0crwdne2934203:0
  13. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4 mm JIS #000 screws.
  14. Canon EOS Rebel T3i Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard away from the camera.
crwdns2935229:020crwdne2935229:0
Natalie Crock
crwdns2935283:008/27/15crwdne2935283:0
785 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-2, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 5-2, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S5G2
crwdns2947412:09crwdne2947412:0
Publicación muy esmerada y didáctica, gracias.
Japons - crwdns2934203:0crwdne2934203:0
There was one huge step left out. On the T3i there is a fiber optic cable connection on the underside, top right hand side of the motherboard. If you don't reconnect this before reassembly your camera won't work. It is difficult to make sure both this cable and the adjacent white round-wire cable are connected before putting the motherboard back in place.
Albert Einstein - crwdns2934203:0crwdne2934203:0
How do you connect it?
art.w.abate -
I'm pretty sure the fiber optical cable is used for the flash. I believe the camera would still work without it connected, but the flash just wouldn't be functional so it still definitely needs to be connected. Also in reply to @octp16dkuy9dbsl, to connect it you just can use a pair of tweezers to push the cable down into the hole in the connector.
Zephosk -
I've edited the guide so it now points out that cable and mentions that it needs to get reconnected. Also I've found removing the top cover of the camera makes reconnecting those cables way easier and in my opinion is worth the extra time to remove the top cover to make reconnecting them easier.
Zephosk -
I concur with Albert Einstein. It was very difficult. This should be mentioned int the steps, not reserved for the comments!
Raymond Pedersen - crwdns2934203:0crwdne2934203:0
Yes, 15 step. to make it easier to connect the optical cable and the second rear cable is better to remove the top cover
Evgeny Rozalenok - crwdns2934203:0crwdne2934203:0
I want to know a camera repair shop where I can send my Canon Rebel T3i.
joleneg4147 - crwdns2934203:0crwdne2934203:0
Will you please get back to me as soon as possible!!!
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 14,194
