Use this guide to replace the front casing on your Canon EOS Rebel T3i.
Locate the battery compartment on the bottom of the camera.
Hook your finger onto the compartment door latch.
Open the battery compartment door.
Remove the battery from the compartment.
Remove the two 3 mm Phillips #000 screws.
Remove the three 3 mm Phillips #000 screws.
Remove the single 6 mm Phillips #000 screw.
Peel back the grip tape with your fingernail.
Remove the four 5 mm Phillips #000 screws.
Slide off the right side of the camera.
After separating the back, gently lift off one side of the light blue wire with the spudger until the connector is totally removed.
With the spudger, remove the orange ribbon cable leading to the circuit board from the back of the camera.
Remove the two 6 mm Phillips #000 screws.
Remove the single 6 mm and two 3 mm Phillips #000 screws.
Use the spudger to lift the plastic under the tripod mount.
crwdns2935229:05crwdne2935229:0
crwdns2917034:0crwdne2917034:0
when I connect and lens the camera replies that the lens is properly connected. One of the copper lens connectors on the camera’s body is kinda greenish rather than gold, so I wanna clean it, how to do that?
