Canon EOS Rebel T3 Tripod Socket Replacement
  1. Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 Tripod Socket Replacement, Front Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel T3 Tripod Socket Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  8. Canon EOS Rebel T3 Tripod Socket Replacement, Tripod Socket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom of the camera, remove the following screws from the tripod socket plate:
    • Two M2.0x3.5mm JIS #000 screws
    • Two M2.0x5.0mm Phillips #000 screws
    • Pull off the tripod socket plate.
crwdns2935103:0crwdne2935103:0
Zephosk
crwdns2935283:009/26/24crwdne2935283:0
5,442 crwdns2915208:0crwdne2915208:0
crwdns2935297:034crwdne2935297:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:045crwdne2931471:0
crwdns2935297:077crwdne2935297:0
crwdns2942667:0crwdne2942667:0 132
