This guide shows you how to replace the rubber grip located on the front right side of the camera.
Pry open the rubber I/F terminal cap with your finger.
Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
On the left side of the camera, remove the following screw:
One M1.7x4.5mm JIS #000 screw
On the right side, remove the following screws:
One M1.7x5.5mm JIS #000 screw
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
Remove the following screws from the bottom of the camera:
Two M1.7x4.5mm JIS #000 screws
Two M1.7x3.0mm JIS #000 screws
Carefully lift the back cover partially off of the camera.
Disconnect the right most ribbon cables from the main PCB board.
Use a plastic spudger to lift up the black locking tab.
Pull out the ribbon cable from its connector using a pair of angled tweezers.
Remove the left ribbon cable using the same two steps as with the other ribbon cable.
Remove the following screws on the front of the camera.
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws:
Slide a spudger tool towards the tripod mount, underneath the plastic cover.
Push the plastic cover up and over the tripod mount.
Pull the front cover off of the camera.
Remove the two 4.5mm JIS #000 screws on the backside of the front cover.
Slide the grip forward and off of the front cover.
