This guide teaches how to to install the back panel latch on your camera.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
Two 4.3 mm Phillips screws
Open the back panel by pushing the locking latch up.
Lift the latch cover off of the camera body.
Slide the side latch (for the back door) up and then lift straight away from the camera body.
