The control dial on the canon EOS A2 lies underneath the top cover of the device. The front cover must also be removed in order to access this.
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
Remove the battery from inside the battery housing and set the cover aside.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Remove the 6.4mm screw from the inside of the flash bezel.
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
Remove the 5.6mm screws behind the battery cover.
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
Remove the 6.4mm screw on the top of the inside edge of the battery hole.
Remove the 4.3mm screw below the camera strap ring.
Remove two 4.8mm screws located on both sides of the eyepiece.
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
Remove the 3mm screw from the back of the control dial while holding the front of the control dial.
On the bottom side of the top bezel, remove the ring, detent ball and spring. Your control dial is now ready to be replaced with a working unit.
crwdns2947412:09crwdne2947412:0
Is it safe to do this procedure while a film is inside the camera?
Giovanni Murru - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was wondering if anyone could help me were I could possibly get the new parts?
I've looked around but found nothing relevant so far.
Thanks in advance,
Agoston Horanyi
horanyiagoston - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you find the parts ? If no go to eBay.
as exemple : https://www.ebay.com/itm/Canon-EOS-A2E-R...
gilberto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm wondering if there is someone who can fix the mode selector for a reasonable price
zekesrule - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How can I open the flash to get to the screw that needs to be removed in order to fix the rotary dial when the rotary dial is moving freely and the camera does not turn on?
Lucas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
