Canon EOS 70D Front Cover Replacement
  1. Canon EOS 70D Front Cover Replacement, Interface Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 70D Front Cover Replacement, Interface Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon EOS 70D Front Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
    • Underneath where the rubber grip was, remove the following screws:
    • Three M1.7x5.5mm Phillips #000 screws
    • Pry off the plastic interface cover.
    • Use a plastic opening tool if a fingernail doesn't work.
  3. Canon EOS 70D Front Cover Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic spudger tool, peel back the rubber grip on the right side of the camera to expose the screws.
    • Remove the following screws underneath the right rubber grip:
    • One M1.7x3.0mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
    • On the back of the camera, remove the following screws:
    • Two M1.7x5.5mm JIS #000 screws
  4. Canon EOS 70D Front Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x3.0mm JIS #000 screws
    • Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
    • Be very careful when lifting the back cover up, there are still two fragile cables attached to it.
    • You can lift the back cover towards the bottom of the camera to get better access to remove the cables.
  5. Canon EOS 70D Front Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a plastic spudger tool, gently lift up on the black locking tab on the ribbon cable connector.
    • Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
    • Use the plastic spudger to gently pry off the other cable connecting the back cover to the camera.
    • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
    • With both of the cables disconnected, you can finish lifting off the back cover from the camera.
  6. Canon EOS 70D Front Cover Replacement, Front Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement, Front Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement, Front Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the right rubber grip off the rest of the way.
    • On the front of the camera, remove the following screws:
    • Two M1.7x5.0mm Phillips #000 screws
    • One M1.7x4.5mm Phillips #000 screw
    • Two M1.7x6.0mm JIS #000 screws
    • On the right side of the camera, remove the following screws:
  7. Canon EOS 70D Front Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 70D Front Cover Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two M1.7x3.0 JIS #000 screws
    • One M1.7x4.5mm JIS #000 screw
    • Use a plastic spudger to pry up on the bottom of the front cover and lift it over the tripod socket.
    • Pull the front cover off the camera body.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
crwdns2935103:0crwdne2935103:0
Zephosk
crwdns2935283:009/26/24crwdne2935283:0
5,457 crwdns2915208:0crwdne2915208:0
crwdns2935297:034crwdne2935297:0
crwdns2942667:0crwdne2942667:0 84
