The main motherboard controls all functions of the camera.
Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
Pull cover over to expose the battery.
Press the white button with your finger to release the battery.
Once released, the battery will eject out about two inches
Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
Use a spudger and pry apart the two plastic hinge-covers surrounding the screen hinge.
Rotate the screen forward 90 degrees and push it back into its housing against the camera.
Use a spudger to peel rubber matting on left hand side to expose camera backplate mounting screws.
Remove three 4 mm Phillip #000 head screws that mount the backplate to the left side of camera.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to pry rubber matting on right hand side to expose backplate mounting screws.
Remove four 4 mm Phillips #000 head screws that mount the backplate to the right side of camera.
Turn camera upside down. Remove five 5 mm Phillips #000 head screws securing the backplate to the bottom of the camera.
Grab the backplate and gently pull away from camera.
Carefully pry open backplate from camera to expose LCD connector (white wire). LCD connector is attached with a metal bar to the motherboard.
Use tweezers to gently pry metal bar connector from camera motherboard.
Remove two 4 mm Phillips #000 head screws that mount the LCD touchscreen to the hinge on the camera.
Grip the screen with your hand and gently pull white connecting wire through hole in backplate.
Once the connector reaches the hole, twist the connector and pull completely through hole.
Use spudger to lift edge of black heat tape.
Slowly peel back black heat tape.
Very carefully, use spudger to remove nine orangish ribbon cables.
Using tweezers remove the two wire cables shown.
Remove seven 5 mm Phillips #000 head screws around motherboard.
Once the five screws are removed, remove the metal chip covered by hand.
Slowly lift motherboard to expose the two cable wires underneath.
Using tweezers, unattach the two wire cables holding the motherboard in.
crwdns2935229:017crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Great write up and illustrations. I'm in the process of repairing a 70D and this will be a great help.
Thank you and keep up the good work!
marcuscleveland85 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, do you know if after replacing the main board it is necessary to configure the camera with some software ? (I heard of spt software)
Stephen Lay - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Tyler my Canon Camera eos 70D isn’t working anymore is it possible to replace the motherboard?
Charlie Laguna - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Je suis à recherche de la carte mère de mon canon 70D. Puis je avoir de l’aide s’il vous plaît. Merci
Mahamadou DEMBELE - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Je suis à la recherche d'une carte mère Pour canon EOS 70d. Aidez-moi svp
kindambi jython - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
