Removing the back cover can be useful if you need to replace it if the screen is broken or if there is some other issue with it. The back cover can also be broken down further, allowing replacement of individual parts found on the back cover assembly if you are able to find individual replacement parts. This guide will not cover disassembly of the back cover itself however, and will only show you how to remove the back cover from the camera.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
Before beginning, remove the battery and SD card from the camera.
Using your thumbs, push up on the eyepiece to remove it.
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
Underneath where the rubber grip was, remove the following screws:
Three M1.7x5.5mm Phillips #000 screws
Pry off the plastic interface cover.
Using the plastic spudger tool, peel back the rubber grip on the right side of the camera to expose the screws.
Remove the following screws underneath the right rubber grip:
One M1.7x3.0mm JIS #000 screw
One M1.7x3.5mm JIS #000 screw
On the back of the camera, remove the following screws:
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws:
Three M1.7x3.0mm JIS #000 screws
Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
You can lift the back cover towards the bottom of the camera to get better access to remove the cables.
With a plastic spudger tool, gently lift up on the black locking tab on the ribbon cable connector.
Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
Use the plastic spudger to gently pry off the other cable connecting the back cover to the camera.
With both of the cables disconnected, you can finish lifting off the back cover from the camera.
