Canon EOS 60D LCD Screen Swivel Assembly Replacement
  1. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Rear LCD Screen Dissasembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Removing Rear Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Removing Rear Cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
  13. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, LCD Screen Swivel Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry off the LCD screen connector up from the motherboard to disconnect it, using the plastic opening tool.
  14. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 2.8 mm Phillips #PH00 black screw on the side of the swivel assembly by using the PH00 screwdriver.
  15. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.8 mm Phillips #PH00 black screws on the back of the swivel assembly using the PH00 screwdriver.
Alejandro Cabrera
crwdns2935283:008/25/15crwdne2935283:0
458 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-6, Wollert Fall 2015 crwdns2935289:0USF Tampa, Team 16-6, Wollert Fall 2015crwdne2935289:0
USFT-WOLLERT-F15S16G6
anybody know how to fix the conection that make the screen turn upside down?
yoeldiamante - crwdns2934203:0crwdne2934203:0
thank you for the tutorial. but it is so wrong, there is no way to reasambly following the steps backward. do it for your self and you will see. there are skipping steps in the disassembly. carefoul anybody who follow this tutorial. i got lost in the reasambly. hope to can figure it out.
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 11,898
