This guide will help you step by step to reach and replace the inner eyepiece of canon EOS 30.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
Separate the inner eyepiece into three parts.
Remove the two 3.6 mm black screws from the outer piece.
Remove the glass panel and replace it.
