The three stacked rings in the lens mount ring can be safely and easily removed.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Remove four 7.1 mm silver screws from lens mount ring.
Remove outer mount ring.
The silver button may detach.
Remove thin gold ring.
Correct orientation is pictured.
Remove thin silver ring.
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
