This fix is safe and only requires a screwdriver.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Remove seven 4.25 mm black screws on the bottom panel.
Remove two 6.5 mm black screws from the panel.
Remove the plastic remote control socket cap by pulling it straight out.
Slide the panel toward the bottom of the camera to remove.
Remove the single 4.8 silver screw from the control socket.
Desolder connections to replace the remote control socket.
Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Remove the two 5.5 mm screws from front of camera.
Remove one black screw from battery door on underside of grip.
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
