Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement
  1. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5.5mm JIS #000 screws for the lens mount ring (silver ring).
    • Remove the two 4mm JIS #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step involves handling sensitive electronics. Avoid static discharge.
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 4mm JIS #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Paul
crwdns2935283:003/12/18crwdne2935283:0
912 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S2-G5, Kim Spring 2018 crwdns2935289:0University of Memphis, Team S2-G5, Kim Spring 2018crwdne2935289:0
UM-KIM-S18S2G5
crwdns2942667:0crwdne2942667:0 2,922
