Canon AE-1 Program Light Seal Replacement
  1. Canon AE-1 Program Light Seal Replacement, Light Seals: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon AE-1 Program Light Seal Replacement, Light Seals: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the camera with the back facing you, and gently pull up on the rewind knob located on the top-left side of the camera using your other hand.
    • This action will release the camera back.
    • Carefully open the back of the camera to reveal the film compartment.
    • Place the camera on a clean, stable surface to access the grooves more easily and work comfortably on removing the old seals.
  2. Canon AE-1 Program Light Seal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect the edges of the camera back door, the hinge area, and the mirror damper (located near the shutter) for old or deteriorating seals.
    • Take note of where the seals need replacing.
  3. Canon AE-1 Program Light Seal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a toothpick or tweezers to carefully scrape out the old, degraded light seals.
    • Be careful not to damage the grooves or scratch the metal surfaces during removal.
  4. Canon AE-1 Program Light Seal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soak a cotton swab in isopropyl alcohol (90% or higher) and gently clean out the grooves where the old seals were located.
    • This will remove any sticky residue and ensure a clean surface for the new seals.
    • Clear the work area of any remnants from the old light seal.
  5. Canon AE-1 Program Light Seal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your replacement seals are not pre-cut, measure the length and width of the grooves and use scissors to cut the foam strips to size.
    • Common areas to replace include:
    • Back door edges: Long, thin strips.
    • Hinge area: Small, thick piece.
  6. Canon AE-1 Program Light Seal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to carefully place the new light seals into the clean grooves.
    • Ensure the seals fit snugly in place without sticking out or causing obstruction to the camera’s closing mechanism.
  7. Canon AE-1 Program Light Seal Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently press the new foam pieces into the spaces ensuring they fit flush within the space.
  8. Canon AE-1 Program Light Seal Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon AE-1 Program Light Seal Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully close the camera back and open it again to check for any gaps or misalignment.
    • Ensure the camera back closes securely without resistance and that the mirror damper is properly installed.
    • Your Canon AE-1 Program is now ready for a test roll to ensure there are no light leaks!
Congratulations! You've successfully replaced the light seals in your Canon AE-1. Enjoy shooting with your refurbished film camera!
Anna Shay
crwdns2935283:009/08/24crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
University of North Alabama, Team A-4, Winner Fall 2024 crwdns2935289:0University of North Alabama, Team A-4, Winner Fall 2024crwdne2935289:0
UNA-WINNER-F24SAG4
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 761
