This repair is useful to know how to execute if your projector has overheating issues. Often, a simple fix is just to replace a malfunctioning fan, which is a relatively cheap part. This is much more cost-effective than replacing the entire projector.
Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
Gently lift up on the shell with both hands, from the back to the front.
Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
Remove the fan by pulling up gently from the top.
Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
The wires will need to be cut with small wire cutters in order to completely remove the fan.
