This guide demonstrates how to replace the top exterior shell for the Canon LV-7210. This repair may be necessary if the projector has sustained cosmetic damage. The only tool you will need for this guide is a screwdriver.
Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
Gently lift up on the shell with both hands, from the back to the front.
