Canary CAN100USBK Top Casing Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Canary CAN100USBK Top Casing Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Top Casing Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Top Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Top Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Top Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Top Casing Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Top Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Top Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Top Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Top Casing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Top Casing Replacement, Front Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Top Casing Replacement, Front Panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two empty nooks underneath the bottom of the panel close to each side of the case.
    • Place the pointed edge of the spudger in one of the nooks under the panel and pry upwards.
  7. Canary CAN100USBK Top Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Adhesive will have to be reapplied after removing the panel.
    • Pull the panel away from the device.
  8. Canary CAN100USBK Top Casing Replacement, Top Casing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Top Casing Replacement, Top Casing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Top Casing Replacement, Top Casing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to carefully pry off the top casing.
    • Alternate pushing up on the left and right sides until the inner clips are released.
    • Do not use too much force or the top may fly off unexpectedly.
  9. Canary CAN100USBK Top Casing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Top Casing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top casing away from the device.
  10. Canary CAN100USBK Top Casing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips #0 screwdriver to remove the two 5mm screws.
Tommy Nguyen
crwdns2935283:002/28/17crwdne2935283:0
597 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G2, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S1-G2, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S1G2
crwdns2942667:0crwdne2942667:0 15
