If your camera's motion detection is creating a lot of false positives, this guide will show you how to replace the infrared blocking filter.
The filter is responsible for blocking infrared light that comes into the camera lens. Once you have removed the lens assembly, you can remove the filter.
The glass filter is located inside a self-contained unit with a battery and cannot be removed from the unit without damaging it. It sits within the camera lens holder. Although the lens holder has two slots, only one screw actually anchors the filter to the lens holder.
A Phillips #0 screwdriver is required for the single screw.
Grip the rubber ring with your fingers and pull up.
Rotate the Canary as you pull out one tab at a time.
Use your Phillips #0 screwdriver to remove the four 6mm screws.
Use the flat end of the spudger to carefully pry off the bottom casing.
Alternate pushing up on the left and right sides until the clips holding the case in are visible.
Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
Pull the ribbon cable out towards the device.
There are two empty nooks underneath the bottom of the panel close to each side of the case.
Place the pointed edge of the spudger in one of the nooks under the panel and pry upwards.
Use the flat end of the spudger to carefully pry off the top casing.
Alternate pushing up on the left and right sides until the inner clips are released.
Pull the top casing away from the device.
Use your Phillips #0 screwdriver to remove the two 5mm screws.
Using a Phillips #0 screwdriver, remove the six 6mm screws.
Grip the circular part of the motherboard and pull it straight out of the device.
Locate the power connector next to the lens protector on the infrared LED board. Using your fingers, wiggle the power connector back and forth until it is loose.
Find the power connector next to the buzzer that is labelled "MIC IR-LED". Use your fingers to wiggle it back and forth until it becomes loose.
Remove the four Phillips #0 6mm screws.
Lift the heatsink up and pull it away from the motherboard.
Lift the infrared LED board directly upwards and pull away from the motherboard.
Remove the two Phillips #0 5mm screws.
Using your forefinger and thumb, grip the top and bottom of the lens assembly and pull away from the motherboard.
Remove the Phillips #0 5mm screw.
Grab the battery end of the filter and pull to slide it out.
