Canary CAN100USBK Ethernet PCB Board Replacement
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
Tommy Nguyen
crwdns2935283:002/28/17crwdne2935283:0
597 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G2, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S1-G2, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S1G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,078
