crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Video Cameracrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
    1. Canary  Connect (Home Internet Security Camera), Cracking Open the Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary  Connect (Home Internet Security Camera), Cracking Open the Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The key to cracking open Canary is in the base. First pop off the rubber foot, and remove four screws.
      • Canary uses multiple screw types. If you ever hope to get it back together, consider a screw management system (here plastic bags for each section of the disassembly).
      • Once you get the base off, you'll need to peel off the front plate (held on with double sticky tape).
    2. Canary  Connect (Home Internet Security Camera), Dissecting the Base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canary  Connect (Home Internet Security Camera), Dissecting the Base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canary  Connect (Home Internet Security Camera), Dissecting the Base: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The base does not do all that much. It holds Ethernet, audio jack, and USB power plugs, along with a steel plate for heft.
      • Note the attention to detail: there's a second PCB board for no apparent purpose other than making the audio jack line up with the USB jack. That's obsession!
      • The little chimney is, in fact, a chimney. The idea is that hot air from the electronics rises, drawing room air. This is an older approach (see grated US patent http://patents.justia.com/patent/6347747 ).
    3. Canary  Connect (Home Internet Security Camera), Heat Sinks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canary  Connect (Home Internet Security Camera), Heat Sinks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canary  Connect (Home Internet Security Camera), Heat Sinks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The inside is dominated by a aluminum plate with dimples for the Ambarella A5S CPU and the back of the image sensor. The heat sink presses against the outer case, through a squishy thermal interface material (TIM).
      • The huge round thing is a buzzer. The round PCB board hosts the 2.4Ghz WiFi and bluetooth antennas (there is no 5Ghz).
      • The infrared LED board sports a plastic frame to aim each LED separately.
    4. Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Canary achieves its flat lens front with an extra sheet of glass that's not optically active. Buried inside is a conventionally shaped M12 security lens.
      • A switchable IR blocking filter is included for day/night mode. This blocks IR light during the day, but switches to be transparent at night.
      • The lens holder is unremarkable. Components are placed within the light chamber to allow the back to support the heat sink.
      • Note the empty holes for... some sort of sensor, not stuffed. Maybe air quality?
      • That's it. I hope you've enjoyed this tour into the insides of Canary.
Bryce Nesbitt
crwdns2935283:011/30/14crwdne2935283:0
1,244 crwdns2915208:0crwdne2915208:0
Hi there! What do they use measure air quality? In fact what is air quality for Canary - CO2 or something else?
Gary - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Would like to know WiFi module model? Artheros?
Chihwei Lu - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 7,020
