Campbell Hausfeld FP204800 Thumb Screw Drain Replacement
  1. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Remove Thumb Screw Drain: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
    • The thumb screw may not easily be removed due to corrosion.
  2. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Apply Teflon Tape: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply teflon tape to the replacement thumb screw drain.
    • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
    • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
Eric
crwdns2935283:010/09/14crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-29, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-29, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G29
crwdns2942667:0crwdne2942667:0 467
