Campbell Hausfeld FP204800 On/Off Switch Replacement
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Caleb Davies
crwdns2935283:010/07/14crwdne2935283:0
528 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-29, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-29, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G29
crwdns2942667:0crwdne2942667:0 1,701
