Cambridge SoundWorks OontZ Angle Plus Speakers Replacement
  1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Rubber Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speaker Grill: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, bend the speaker cover upward and it will slide out.
  11. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With some force, push the motherboard straight in toward the center of the device.
  12. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This makes the motherboard fit in the groove rather tight.
  13. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the speaker's connector from the motherboard.
  14. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the eight screws holding the speakers in place.
  15. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the the wires connected to the back side of both speakers.
  16. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully push the speakers out one at a time.
David Rice
crwdns2935283:002/10/16crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Nance Spring 2016 crwdns2935289:0USF Tampa, Team 1-1, Nance Spring 2016crwdne2935289:0
USFT-NANCE-S16S1G1
crwdns2942667:0crwdne2942667:0 2,007
