Cambridge Audio A3i Motherboard Replacement
  1. Cambridge Audio A3i Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cambridge Audio A3i Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. Cambridge Audio A3i Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Cambridge Audio A3i Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cambridge Audio A3i Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
Colby
crwdns2935283:004/15/10crwdne2935283:0
356 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-36, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 28-36, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S28G36
crwdns2942667:0crwdne2942667:0 6,904
