Cable set up
  1. Cable set up, Cable set up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
  2. Cable set up: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
  3. Cable set up: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert power cable into socket.
Nikolai
crwdns2935283:010/12/11crwdne2935283:0
254 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-14, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-14, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G14
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,026
