CR-10S PRO Linear Rail Kit Hotend install
  1. CR-10S PRO Linear Rail Kit Hotend install, Hotend Removal down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Hotend Removal down: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Hotend Removal down: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Hotend cover screw
    • Remove the Hotend mounting screws
  2. CR-10S PRO Linear Rail Kit Hotend install, Belt removal and Stock X Carriage: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Belt removal and Stock X Carriage: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Belt removal and Stock X Carriage: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen Idler pulley bracket screws and remove the idler pulley bracket
    • Remove the belt
    • Remove the lower V-slot wheel bolt from X-carriage
  3. CR-10S PRO Linear Rail Kit Hotend install, Mounting screw Pattern & Sliding on the Rail: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Mounting screw Pattern & Sliding on the Rail: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Mounting screw Pattern & Sliding on the Rail: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the table for the recommended mounting locations
    • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
    • For rails with an odd number of mounting holes, the pattern will overlap in the middle
    • For rails with an even number of mounting holes, the pattern will be continued across the rail
    • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
    • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
    • The guide helps to slide the T-nuts into the extrusion
  4. CR-10S PRO Linear Rail Kit Hotend install, Mounting the Rail: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Mounting the Rail: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, Mounting the Rail: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
    • Use both Linear rail Guide to center the rail to the Aluminum extrusion
    • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
  5. CR-10S PRO Linear Rail Kit Hotend install, X Carriage install: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, X Carriage install: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, X Carriage install: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Belt adaptor
    • 4x M3x8 SHCS
    • 3x M3 split washers
    • M3 Hex nuts
    • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
    • Push up on the belt bracket, it is square against the bottom of the carriage block.
    • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
    • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
  6. CR-10S PRO Linear Rail Kit Hotend install, CR10S PR0 V1/V2 HE Install: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press in all 4 M3 HEX NUTS from the back of the adaptor before install on linear rail block
    • Hotend mounting screws
    • Stock Hotend M3x20 SHCS(5mm longer than stock) with split lock washer
    • MicroSwiss Hotend M3x20 SHCS(+6mm longer than stock)
    • BL Touch Mount
    • M3x8 BHCS (+4mm longer than stock)
    • Stock Fan cover screws Note-start both screw before fully tightening the screw
    • M3X6 BHCS (+2mm longer than stock)
  7. CR-10S PRO Linear Rail Kit Hotend install, BL touch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CR-10S PRO Linear Rail Kit Hotend install, BL touch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
AJ Pereira
crwdns2935283:005/29/20crwdne2935283:0
2.707 crwdns2915208:0crwdne2915208:0
Tiny Machines 3D crwdns2935289:0Tiny Machines 3Dcrwdne2935289:0
Community
crwdns2935297:041crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,787
