CHI Original Circuit Board Replacement
  1. CHI Original Circuit Board Replacement, Hinge Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CHI Original Circuit Board Replacement, Hinge Spring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
    Where do I find a new power cord?
    ElenaStar* - crwdns2934203:0crwdne2934203:0
  2. CHI Original Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the .53" long screw from the hinge pin.
    This picture is out of order
    fixitman - crwdns2934203:0crwdne2934203:0
    You should only have to remove the back two screws and not any screws near the switch.
  3. CHI Original Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hinge pin.
  4. CHI Original Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the two halves of the CHI Original.
  5. CHI Original Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CHI Original Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Circuit Board Replacement, Power Cord: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CHI Original Circuit Board Replacement, Power Cord: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull upwards on the connection point and disconnect the power cord.
    What is part this person is holding in his right hand then clear part
    Rafael - crwdns2934203:0crwdne2934203:0
  8. CHI Original Circuit Board Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CHI Original Circuit Board Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CHI Original Circuit Board Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
  9. CHI Original Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CHI Original Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CHI Original Circuit Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the covers on both halves.
  10. CHI Original Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) .15" Phillips screws from the circuit board.
  11. CHI Original Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CHI Original Circuit Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
Eric Knigga
crwdns2935283:008/23/17crwdne2935283:0
248 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G2, Freund Fall 2017 crwdns2935289:0IUPUI, Team S1-G2, Freund Fall 2017crwdne2935289:0
IUPUI-FREUND-F17S1G2
I used most of this guide through step 10 after dropping this in water; I didn't take out the power cord. I left the partially disassembled straightener in a container with desiccant overnight to remove the moisture. There was some corrosion on the switch that prevented the device from turning off that I cleaned up with isopropyl alcohol . I confirmed the switch behavior before and after cleaning with a multimeter to check continuity. On my device, the contact closest to the heating element was supposed to be disconnected from the other two contacts when off; when on, they were all showing contact. Before cleaning, there was continuity between all contacts. Thanks for the guide.
bnh8 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 3,629
