C-shaped Shower Door Handle Replacement
  1. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the socket head cap screw on the bottom arm of one door handle.
    • Only one handle will have the cap screws—one on the top and one on the bottom arm.
    • Insert the Allen wrench into the cap screw hole.
    • Rotate the Allen wrench counterclockwise to loosen the screw.
  2. C-shaped Shower Door Handle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw has been loosened, gently pull the handle away from the door.
  3. C-shaped Shower Door Handle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps 1 and 2 for the top of the handle.
    • Carefully remove the handle.
  4. C-shaped Shower Door Handle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the remaining handle, insert the Phillips #2 screwdriver into the bottom screw.
    • Turn the screwdriver counterclockwise to loosen the screw.
    • Remove the screw cap, screw, and washer.
    • There may be several parts to the screw and washer set. This example has a brass screw cap, a screw, a larger 1.25" metal washer and plastic washer, and the interior, 3/4" plastic washer.
  5. C-shaped Shower Door Handle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disassemble the screw and washer set.
    • Remove the old or damaged interior plastic washer and discard.
  6. C-shaped Shower Door Handle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the new plastic washer onto the screw.
    • This may require threading the washer onto the screw if the hole is snug.
    • After you have threaded the new washer, reassemble the remaining parts of the screw set in reverse order.
  7. C-shaped Shower Door Handle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the threaded screw set back through the shower door and handle.
    • Tighten the screw with the Phillips screwdriver, taking care not to overtighten or strip the screw.
  8. C-shaped Shower Door Handle Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps 4-7 with the top screw.
  9. C-shaped Shower Door Handle Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once both screws are tightened, slide the other handle back onto the screws.
  10. C-shaped Shower Door Handle Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 C-shaped Shower Door Handle Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten the cap screw on the top part of the handle with the Allen wrench.
  11. C-shaped Shower Door Handle Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat with the bottom cap screw.
  12. C-shaped Shower Door Handle Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test both sides of the handle by gripping each one and gently pulling them back and forth.
    • If the handle is properly secure, there should be no movement.
Jennifer Judd
crwdns2935283:009/19/24crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-14, Friess Fall 2024 crwdns2935289:0University of North Texas, Team 1-14, Friess Fall 2024crwdne2935289:0
UNT-FRIESS-F24S1G14
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 445
