Butane Replacement in a Handheld BIC Lighter
  1. Butane Replacement in a Handheld BIC Lighter, Refill Butane in a Bic lighter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution -- Butane is flammable and dangerous when inhaled. Because of this, it is important to do this fix in a well ventilated space and ensure a complete seal when refilling the Bic lighter.
    • Identify the small, circular dent in the bottom in the BIC lighter.
    • Push the push pin's metal tip into this dent until the bead that seals it pops loose. You will be able to hear and feel this.
  2. Butane Replacement in a Handheld BIC Lighter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your can of Butane and put the rubber ingot over the tip of the nozzle.
    • Make sure that the hole in your ingot lines up with the hole in the Butane nozzle. This is to make an airtight seal so that the Butane doesn't leak out.
  3. Butane Replacement in a Handheld BIC Lighter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the Butane nozzle to the hole you made in the bottom of the lighter. Make sure the rubber ingot is snug.
    • Press down on the Butane nozzle and begin filling the lighter, which takes around 30 seconds.
  4. Butane Replacement in a Handheld BIC Lighter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • QUICKLY -- remove the Butane nozzle from the bottom of the lighter and put your thumb over the hole in the lighter to seal it.
    • Do this quickly to make sure no Butane escapes. You will be able to hear noise if gas is escaping.
  5. Butane Replacement in a Handheld BIC Lighter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • QUICKLY -- Insert the push pin back into the hole in the lighter. Make sure to push it in all the way to make a secure seal.
    • Before sparking your lighter, wash your hands and go to a different space to ensure no possible Butane in the air ignites.
    • Optional -- To finish, use the wire cutters to shorten the push pin and file it smooth with the metal file. Make sure to leave some of the plastic from the push pin to help the lighter remain sealed.
Stan Kirby
crwdns2935283:004/08/23crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 51-7, Peters Spring 2023 crwdns2935289:0University of Memphis, Team 51-7, Peters Spring 2023crwdne2935289:0
UM-PETERS-S23S51G7
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 1,379
