Busch + Müller Toplight 2C permanent battery replacement
  1. Busch + Müller Toplight 2C permanent battery replacement, Sawing to open the housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Sawing to open the housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Saw the lamp along the ultrasonic welding seam with a fine saw (e.g. Japanese saw).
    • A total of four straight cuts must be made
    • Saw carefully so that the electronics or the battery do not get damaged
  2. Busch + Müller Toplight 2C permanent battery replacement, Open housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Open housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Open housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The housing should fall apart into two halves after sawing
  3. Busch + Müller Toplight 2C permanent battery replacement, Remove battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Remove battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the old battery out of the socket
    • The plug may be relatively tight in the socket. Simply wiggle it until it can be pulled out or use pliers
  4. Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Disassemble & recycle battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Under the black foil there are two Li-Io cells in AAA size.
    • At the two outer ends are the negative terminals, which are connected with a metal clip
    • Remove the round stickers and the long metal clip
    • Remove the cables including the socket
  5. Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Prepare new batteries: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Buy 2x ICR10440 with solder tag
    • (The batteries used here are ICR10440; 3,7V each 320mAh with Z-solder tag)
    • Put the batteries with the positive side to each other and solder the lugs
    • Now solder the red connection cable
  6. Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Soldering and packing new batteries together: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The outer solder lugs are soldered to the sheet metal (paper clip as soldering aid).
    • The black connection cable is also soldered to the sheet metal
    • Stick the yellow adhesive tape on the open contacts
    • Stick the circular red stickers on the outer positive terminals again
    • Fix the new battery pack with insulating tape.
  7. Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Assembly / Mounting: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug the power connector into the socket of the board
    • Insert the board into the black housing with the USB socket pointing downwards
    • Put on the reflector
    • To make the housing watertight again, the previously sawed seam must be glued together with a gap-filling adhesive. This can be done for example with Sikaflex
  8. Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Bonding the housing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply glue carefully along the contour (e.g. Sikaflex)
    • Make sure that the LEDs and the switch remain clean.
    • Close the housing and let the glue harden.
  9. Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Busch + Müller Toplight 2C permanent battery replacement, Ready, function test: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clip the lamp into the holder
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Fritz
crwdns2935283:007/11/17crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 2,792
