Brother XR-40 Lightbulb Replacement
  1. Brother XR-40 Lightbulb Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Lightbulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Lightbulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Lightbulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel.
  5. Brother XR-40 Lightbulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Lightbulb Replacement, Lightbulb: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using scissors, clip the two zip ties securing the lightbulb wire.
  7. Brother XR-40 Lightbulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the machine on its side, with access to the bottom.
    • Gently pull out the white wire connecting the bulb to the machine.
  8. Brother XR-40 Lightbulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the wire out from under the plastic hook.
  9. Brother XR-40 Lightbulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
  10. Brother XR-40 Lightbulb Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lightbulb assembly.
Kevin Bickers
crwdns2935283:002/05/14crwdne2935283:0
673 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 2-12, Amido Winter 2014 crwdns2935289:0Cal Poly, Team 2-12, Amido Winter 2014crwdne2935289:0
CPSU-AMIDO-W14S2G12
crwdns2942667:0crwdne2942667:0 3,268
