Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Tape Cassette: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-1290 Tape Cassette Replacement, Tape Cassette: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 Tape Cassette Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-1290 Tape Cassette Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 Tape Cassette Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-1290 Tape Cassette Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 Tape Cassette Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 Tape Cassette Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
Lorraine Canez
crwdns2935283:010/25/14crwdne2935283:0
318 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-4, Johnson Fall 2014 crwdns2935289:0Gateway, Team 1-4, Johnson Fall 2014crwdne2935289:0
GCC-JOHNSON-F14S1G4
Wie wird die Kassette eingesetzt
Uwe Seiler - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 20,221
