Brother PT-110 Keypad Contacts Replacement
  1. Brother PT-110 Keypad Contacts Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries.
  3. Brother PT-110 Keypad Contacts Replacement, Back Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement, Back Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew both 6 mm Phillips #1 screws from the circuit board.
    • Total screws: 2
  10. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the circuit board out.
  11. Brother PT-110 Keypad Contacts Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the keypad contacts up from the plastic casing.
Kimberly Larsen
crwdns2935283:009/28/16crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Harley Fall 2016 crwdns2935289:0IUPUI, Team 1-1, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S1G1
crwdns2942667:0crwdne2942667:0 394
