Brother PT-1010 Keyboard Replacement
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
Haley Sweet
crwdns2935283:010/30/14crwdne2935283:0
460 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-4, Williams Fall 2014 crwdns2935289:0Baylor, Team 4-4, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S4G4
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - crwdns2934203:0crwdne2934203:0
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,320
