Brother MFC-J4420DW Power supply replacement
  1. Brother MFC-J4420DW Power supply replacement, Removing hood holder: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Removing hood holder: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Removing hood holder: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the power cord of the printer
    • Open the printer as you would to access the USB port.
    • Pull out the rear end of the hood holder (see picture two). After that you can remove the top part of the hood holder.
    • Now remove the hood holder completely.
    • It is quite useful to put the printer near something so that you can lean the top against something, for example a wall.
  2. Brother MFC-J4420DW Power supply replacement, Removing cables connected to the top part of the printer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Removing cables connected to the top part of the printer: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Removing cables connected to the top part of the printer: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next remove the cover on the left side of the printer (lift the right side of the cover first).
    • Unplug the black ribbon cable, the blue and the white plugs from its sockets and unscrew the cable which is attached with a screw (see second image)
    • Remove the red and white plugs from its sockets as shown in picture three.
  3. Brother MFC-J4420DW Power supply replacement, Remove the top part of the printer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Remove the top part of the printer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Remove the top part of the printer: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the plastic part shown in picture one up to the top part of the printer
    • Now you can easily remove the top of the printer by pushing it away from the printer (not up).
  4. Brother MFC-J4420DW Power supply replacement, Remove cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Remove cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws connecting the black plastic cover to the printer (see image)
    • Remove the cover
    • The following steps are based on the Brother Inkjet DCP/MFC Service Manual MODELS: DCP-J4120DW MFC-J4320DW/J4420DW MFC-J4520DW MFC-J4620DW/J4625DW. In particular, step 9.29 “Power Supply PCB ASSY”.
  5. Brother MFC-J4420DW Power supply replacement, Disconnect the cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector with the many red cables. (Already removed in the picture. The other plugs do not need to be removed.)
  6. Brother MFC-J4420DW Power supply replacement, Remove screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-J4420DW Power supply replacement, Remove screws: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two screws that need to be removed.
  7. Brother MFC-J4420DW Power supply replacement, Remove the power supply unit: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the clip so that the power supply unit can be removed downwards.
  8. Brother MFC-J4420DW Power supply replacement, Power supply: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is what the power supply looks like.
    • It is labeled B57U152-2 LF1
    • A possible starting point here is the soldered fuse F1. According to the circuit board, “250V T2.5AH”.
    • However, the fuse may only be a symptom and not the cause. See for example the article https://www.mikrocontroller.net/topic/50...
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
FeLa
crwdns2935283:009/26/24crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
Hi,
Top Anleitung , bei mir ist der Mosfet durchgebrannt , mal schauen was ich jetzt mache
Wilhelm - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 217
crwdns2942667:0crwdne2942667:0 2,189
