Brother MFC-490CW Scanning Glass Replacement
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
George Kielpinski
crwdns2935283:010/30/14crwdne2935283:0
50 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-4, Miles Fall 2014 crwdns2935289:0UMass Dartmouth, Team 4-4, Miles Fall 2014crwdne2935289:0
UMASSD-MILES-F14S4G4
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 5,169
