If your Brother HL-L2400D printer produces faded prints, streaks, or error messages indicating that the drum needs replacement, it’s time for a new drum unit. The drum is a critical component that transfers toner onto paper; over time, it wears out and affects print quality.
This guide will walk you through the step-by-step process of replacing the drum in your Brother HL-L2400D, ensuring smooth operation and high-quality prints. Whether you’re a beginner or experienced with printer maintenance, our instructions will make the process quick and hassle-free.
Let’s get started!
Open the front cover of the printer.
Grab the green tab and pull the part out.
Place the drum onto a sheet of paper.
Press the green tab on the side to pop out the inside component.
Press the green tab firmly until you hear a noise.
Pull out the drum using the closest grey part to you.
Place your new replacement drum inside.
Press the new drum firmly.
To clean the imaging of the drum, use the slider above.
Make sure to go back and forth with the slider several times.
Place your replaced part back into the printer.
Press and hold the "Go" button at the bottom of the printer.
Let go once all four of the button's LEDs are lit up.
You have successfully replaced the drum! Contact a local recycling centre or a specialized recycling service for instructions on properly disposing of the cartridge or drum unit.
