This guide will teach you how to replace the metal needle plate on the Brother CS6000i. You will need a Phillips #2 screwdriver as well as a 4mm flathead screwdriver. It will take about 15-20 minutes.
Remove the five 20 mm Phillips #2 screws on the back of the device.
Remove the single 28 mm Phillips #2 screw on the back of the device.
Remove the single 23 mm Phillips #2 screw on the back of the device.
Remove the final screw, a 11 mm Phillips #2.
Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
Unhook the white wires that are connected to the motherboard.
Fully separate the two halves.
Remove the two screws securing the needle plate with a 4mm flathead screwdriver.
