Brother CS-80 Tire Ring Replacement
  1. Brother CS-80 Tire Ring Replacement, Tire Ring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement, Tire Ring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement, Tire Ring: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the machine.
    • Unplug both the power cord and the foot pedal.
  2. Brother CS-80 Tire Ring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the clear flap to the left to remove it.
  3. Brother CS-80 Tire Ring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the latch to detach the bobbin cover.
  4. Brother CS-80 Tire Ring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bobbin from the bobbin shuttle.
  5. Brother CS-80 Tire Ring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to pry off the plastic plate that surrounds the bobbin shuttle.
  6. Brother CS-80 Tire Ring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the bobbin winder cover.
    • Flip up the spool pin.
  7. Brother CS-80 Tire Ring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the grey bobbin winder seat from the bobbin winder shaft.
  8. Brother CS-80 Tire Ring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 13 mm Phillips head screw from the left side of the bobbin winder.
    • Place the screw on a magnet (or in a tray) to ensure you don't lose it.
  9. Brother CS-80 Tire Ring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the bobbin winder thread spool pin and the attached bottom plate of the bobbin winder area.
    • Use a flathead screwdriver to assist you in removing the plate.
  10. Brother CS-80 Tire Ring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 mm Phillips screw from the metal plate to the right of the motherboard.
  11. Brother CS-80 Tire Ring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the thread compartment.
    • Press the back level on left side of the machine to eject the thread cassette compartment.
  12. Brother CS-80 Tire Ring Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the thread cassette compartment by pulling it up.
    • Remove the front clear shield to the thread cassette compartment holder by pulling it away from the machine.
  13. Brother CS-80 Tire Ring Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 19 mm Phillips head screw from the back of the internal thread cassette compartment area.
  14. Brother CS-80 Tire Ring Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the machine so the back is facing you.
  15. Brother CS-80 Tire Ring Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three large 19 mm Phillips head screws from the back left face of the machine.
  16. Brother CS-80 Tire Ring Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 19 mm Phillips head screw from behind the handle of the machine.
  17. Brother CS-80 Tire Ring Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the large 19 mm Phillips screw from the bottom right of the machine.
    • You should have removed a total of five 19 mm large screws from the back face.
  18. Brother CS-80 Tire Ring Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 33 mm Phillips head screw by the presser foot lever.
  19. Brother CS-80 Tire Ring Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull apart the two sides of the sewing machine.
    • The two halves will still be partially attached by cables on the inside. Take care not to damage any of the cables.
  20. Brother CS-80 Tire Ring Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect the ribbon cable from the motherboard.
  21. Brother CS-80 Tire Ring Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 6-pin connector from the motherboard.
  22. Brother CS-80 Tire Ring Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Completely pull apart the two halves of the machine.
    • Set aside the front side piece.
    • Place the back piece down so that the inside faces upwards.
  23. Brother CS-80 Tire Ring Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the gold 9 mm Phillips screw from the front right of the motherboard.
    • Remove the two silver 7 mm Phillips head screws from the front and back of the left side of the motherboard.
  24. Brother CS-80 Tire Ring Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide out the motherboard from the white plastic motherboard housing.
    • Handle the motherboard gently to avoid damaging the circuits or connectors.
  25. Brother CS-80 Tire Ring Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 3-pin connector from the front left side of the motherboard.
  26. Brother CS-80 Tire Ring Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 4-pin connector from the left underside of the motherboard.
  27. Brother CS-80 Tire Ring Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over so it rests upside down and away from the balance wheel.
  28. Brother CS-80 Tire Ring Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to pry off the tire ring.
    • The tire ring may have disintegrated and deposited black rubber on the inside of the machine. If so, clean the area with cotton swabs damp with isopropyl alcohol and paper towels. Wearing disposable gloves is recommended.
  29. Brother CS-80 Tire Ring Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brother CS-80 Tire Ring Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the new tire ring onto its seat.
    • You may need to use a flathead screwdriver to help it seat fully.
To reassemble your sewing machine, follow the disassembly instructions in reverse order.
Edyn
crwdns2935283:004/25/24crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-5, Whithaus Spring 2024 crwdns2935289:0UC Davis, Team 1-5, Whithaus Spring 2024crwdne2935289:0
UCD-WHITHAUS-S24S1G5
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 634
