Broken Zipper On Luggage Replacement
  1. Broken Zipper On Luggage Replacement, Zipper: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal stopper at the end with the pliers (which ever set works for your size zipper), using a bit of pressure to pry it off of the slider. This will help the current, broken zipper come off easier.
    You have highlighted the zipper slider but say to remove the metal stopper. What do you mean?
    Simon Bird - crwdns2934203:0crwdne2934203:0
    Misleading photo.
    There is no metal stopper. If there is one, it’s inside the fabric (where the zipper ends). OR, there is no metal stopper. The zipper goes inside that fabric at the end. You’ll have to remove the stitches to expose the end of the zipper. You need access to the end of the zipper to be able to slide in the new slider.
    After that, you’ll have to resew the fabric “stopper”.
    Kelly J - crwdns2934203:0crwdne2934203:0
  2. Broken Zipper On Luggage Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers. Apply pressure vertically to pry the zipper away from the teeth of the slider.
    • Use the other pair of pliers to keep the zipper in place while you remove it. It should then smoothly slide off of the slider.
  3. Broken Zipper On Luggage Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new zipper. To do this, simply slide the new zipper over the end of the slider chain in the same direction than the old one. This should secure the teeth together for a comfortable fit.
    How do you get access to the end of the slider chain?
  4. Broken Zipper On Luggage Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Applying pressure, use pliers to reattach the metal zipper stopper.
    Where is the zipper stopper? how did you remove it?How do you reattach it? How did you get the new zipper slider on?
  5. Broken Zipper On Luggage Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure the new zipper, using the pliers, setting the stoppers back in place and molding it back together.
    How do you secure the new zipper?
Mold and bend the stopper, using the pliers, to set the stopper back in place.
crwdns2935229:05crwdne2935229:0
Ashley Cooper
crwdns2935283:001/19/18crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 crwdns2935289:0USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018crwdne2935289:0
USFSM-STEWART-S18S1G1
crwdns2931471:015crwdne2931471:0
crwdns2935297:028crwdne2935297:0
Thank you. I am about to try this. A few suggestions— you say we need a screwdriver but don’t actually describe using it. It would helpful to identify the three parts of the zipper— the pull , the slider train and the stop—right at the beginning, and be consistent throughout.
aurora - crwdns2934203:0crwdne2934203:0
Thanks for trying to help but you seem to miss out all the critical (difficult) steps. I have read the guide and still have no better idea of what to do.
These recommendations are completely incomprehensible. I recommend a visit to the Zipper Rescue website.
David Hammel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 64
crwdns2936753:07crwdne2936753:0 382
crwdns2936753:030crwdne2936753:0 1,734
crwdns2942667:0crwdne2942667:0 161,894
