The following steps will document the process of replacing a Broan-Nutone range hood filter (Broan EW4830SS). There are not many steps involved, and the whole process should be completed within a few minutes. The only thing needed for this fix is a paper towel, which isn’t imperative to have, but it helps with the cleaning part of it. While doing the fix, make sure the stove is off as it is a safety hazard which can lead to possible injury if left on.
Turn on the range hood light to see better during the fix.
Remove the old filter by pulling it down as you press the button.
Wipe down the area with a paper towel to clean any grease or other residue.
Insert the new filter and make sure it is lined up correctly to fit.
Turn on the range hood to see if it is working correctly.
