BrightSign 4K Battery Charging Port Replacement
  1. BrightSign 4K Battery Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. BrightSign 4K Battery Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. BrightSign 4K Battery Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. BrightSign 4K Battery Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. BrightSign 4K Battery Charging Port Replacement, Motherboard Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement, Motherboard Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. BrightSign 4K Battery Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard out of the casing.
  7. BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over so the heatsink is facing down.
    • Desolder the four solder joints and remove the melted solder with the pump.
  8. BrightSign 4K Battery Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BrightSign 4K Battery Charging Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Using the tweezers apply pressure to the spade head clip shown.
    • Remove the charging port by pulling the piece off.
Nhi Pham
crwdns2935283:002/15/18crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S17-G6, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S17-G6, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S17G6
crwdns2942667:0crwdne2942667:0 377
