Briggs and Stratton 675 Series Repair Pull Cord Replacement
  1. Briggs and Stratton 675 Series Repair Pull Cord Replacement, Pull Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before begining.
    • Use a Phillips #2 screwdriver to remove the two 25mm screws on top of the engine cover.
  2. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to lift the engine cover off, separating it from the rest of the engine.
    • Slip the pull cord through the engine top cover after separating it.
  3. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a socket wrench with a 5/16" socket to remove the three 17mm screws that keep the fuel tank attached.
    • Tilt the fuel tank back at least 45 degrees to get it out of your way.
  4. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a socket wrench with a 3/8" socket to remove the two 26mm screws at the back of the engine shield.
    • Use a socket wrench with a 5/16" socket to remove the 17mm screw on the top of the engine shield.
  5. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the oil funnel from the rest of the engine. It should pull away easily and come off completely.
    • Make sure there isn't an overflow of oil in the funnel or hose before removing it to avoid spilling.
  6. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a socket wrench with a 3/8" socket to remove the two 20mm screws on the front of the engine shield.
  7. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the engine shield and flip it over.
  8. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you are missing a pull cord, skip straight to step 9.
    • Pull the cord back until it is completely unwound from the starter mechanism spool.
    • Wedge a screwdriver into the gap to hold the spool in place.
    • Cut the end of the pull cord with scissors or a knife.
  9. Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Briggs and Stratton 675 Series Repair Pull Cord Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the hole on the outside of the engine shield with the hole on the inside, then slip the new pull cord through and tie a knot.
Andrew Saunders
crwdns2935283:002/01/15crwdne2935283:0
957 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-31, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-31, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G31
crwdns2944067:012crwdne2944067:0
Thanks alot for this guide. I was able to get the pull cord fixed without hassle at all. When I saw my string about to break I knew I was about to blow a bunch of money to have it fixed. Thanks again!
howellgerald - crwdns2934203:0crwdne2934203:0
Anyone know how to fix a carb fire
Cody Nitardy - crwdns2934203:0crwdne2934203:0
took me right through to the part where the cord is run but not wound and pretensioned ready for start, now what?
Duncan Laurie - crwdns2934203:0crwdne2934203:0
Go back to step 8, where it says to pull the cord out and wedge a screwdriver in the spool to hold it under tension. If you have no cord on the spool, you'll have to rotate it to put the spool under tension, then wedge a screwdriver in to hold it, insert the new cord, tie the knot, then remove the screwdriver to release the tension, so the spool will wind the cord up.
chris04528 -
Spring unwind how to replace it
Bobby - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 93
crwdns2936753:030crwdne2936753:0 405
crwdns2942667:0crwdne2942667:0 47,679
