Removing the air filter is really simple. It only takes one one screw to be removed and the rest can be done with your hands. The air filter should be replaced annually.
Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
Use your hands to pull the air filter case out of the hinge at the bottom.
Simply remove the air filter with your hands.
Good information, although it didn't resolve my issue. Thanks for sharing
This is a power wash motor water will not come out
