Breville BKC600XL Water Valve Replacement
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Water Valve Replacement, Silver Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Water Valve Replacement, Silver Casing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Antonio
crwdns2935283:009/26/12crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-3, Propen Fall 2012 crwdns2935289:0Cal Poly, Team 1-3, Propen Fall 2012crwdne2935289:0
CPSU-PROPEN-F12S1G3
crwdns2935297:018crwdne2935297:0
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,064
